404 Page Not Found Error Sorry, the page you were looking for does not exist. Try our Site Search: Go to the Homepage or Sitemap to navigate the site. Or Take a Look at our Most Popular Products DI-1100USB Data Acquisition Starter Kit$59 4 differential armored analog inputs 12-bit measurement resolution ±10 V fixed measurement range 20-40 kHz sample rate per channel Includes WinDaq software Includes .NET Class Fully documented command protocol Go to Product Page DI-2008V, mV, Thermocouple, Pulse DAQ$349 4 or 8 differential and isolated channels Voltage or TC type per channel Expandable using ChannelStretch™ 16-bit measurement resolution ±10mV to ±50V measurement range Rate and count inputs Includes WinDaq and .NET class Go to Product Page DI-730-USBUSB Industrial Data Acquisition$3195 8 isolated wide range channels ±10mV to ±1000V measurement ranges Supports 8B industrial amplifier backpack 150 kHz max sample rate Small, highly portable form factor Go to Product Page DI-808Web-based Data Logger$995 Works with any smart device TC, mV, V, pulse inputs Advanced triggering functions Alarm outputs with email/text alerts Record to Internal memory or Flash Drive Manage, receive and retrieve data from virtually anywhere Go to Product Page Model DI-2108High Speed USB DAQ$169 4 or 8 differential analog inputs ±10V measurement range Up to 220 kHz throughput 16-bit measurement resolution Anti-aliasing Filter per Channel 7 Digital Ports with rate and count Records to PC or USB flash memory Includes WinDaq and .Net class Go to Product Page DI-4718B-UUSB Data Acquisition$695 8 analog inputs 160 kHz max sample rate Any industrial measurement Uses isolated 8B amplifier modules Anti-aliasing Filter per Channel Records to PC or USB flash memory Expandable using ChannelStretch™ Includes WinDaq software Go to Product Page GL240Stand-alone USB data logger$995 10 isolated analog/4 counter channels Sample intervals from 10ms to 1 hour ±20mV to ±100V programmable ranges Supports TC measurements Record to PC, USB drive, flash Measure RH model B-530 Go to Product Page DI-4108-E High Speed USB/Ethernet DAQ $449 8 differential analog inputs Expandable using ChannelStretch™ 16-bit measurement resolution ±200mV to ±10V measurement range Anti-aliasing Filter per Channel 160 kHz analog throughput rate Records to PC or USB flash memory Includes WinDaq software Go to Product Page DI-710-UHSStand-alone USB Data Logger$599 16 analog inputs 14.4 kHz max sample rate ±1.25 V to ±10 V programmable ranges Records to PC or SD memory Measure environmental temperature& humidity with HMP60 probe Go to Product Page EL-WiFi-THWiFi Temperature and Humidity Data Logger$171.99 Environmental -20°C to +60°C (-4°F to +140°F), 0 to 100% RH ±1°C, ±3% RH overall accuracy Battery-operated Time and date stamps all data Stores data to local PC or The Cloud Go to Product Page
