Reference Materials > Gain Factors and Settings
All products with programmable gain and PGL/PGH settings (if applicable).
DI-155
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-50V
2
1
+/-25V
4
2
+/-12.5V
5
3
+/-10V
8
4
+/-6.25V
10
5
+/-5V
16
6
+/-3.125V
20
7
+/-2.5V
DI-149 and DI-155 Rate channel 9
WinDaq Acquisition
Gain Setting
Gain Index
Range
2
1
0-10 kHz
4
2
0-5 kHz
10
3
0-2 kHz
20
4
0-1 kHz
40
5
0-500 Hz
100
6
0-200 Hz
200
7
0-100 Hz
400
8
0-50 Hz
1000
9
0-20 Hz
2000
10
0-10 Hz
4000
11
0-5 Hz
DI-1120 and DI-4208
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-100V
2
1
+/-50V
5
2
+/-20V
10
3
+/-10V
20
4
+/-5V
50
5
+/-2V
DI-4108
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-10V
2
1
+/-5V
5
2
+/-2V
10
3
+/-1V
20
4
+/-0.5V
50
5
+/-0.2V
DI-2108-P
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-10V
2
1
+/-5V
4
2
+/-2.5V
For gain indices 0 and 1, adding 1000 to ADChannelList channel numbers can specify a unipolar channel with min range 0V.
DI-1110, DI-1120, DI-2008, DI-2108, DI-2108-P, DI-4108, and DI-4208 Rate channel 9
WinDaq Acquisition
Gain Setting
Gain Index
Range
2
1
0-50 kHz
5
2
0-20 kHz
10
3
0-10 kHz
20
4
0-5 kHz
50
5
0-2 kHz
100
6
0-1 kHz
200
7
0-500 Hz
500
8
0-200 Hz
1000
9
0-100 Hz
2000
10
0-50 Hz
5000
11
0-20 Hz
10000
12
0-10 Hz
For rate channel 9 in any of the above devices, the upper byte of the ADDiffList table entry specifies a moving-window filter length for rate computation, from 0 for noisy and responsive to 63 for smooth and delayed (resulting in filter lengths 1 through 64).
DI-245 and DI-2008
Voltage
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
8
+/-50V
2
9
+/-25V
5
10
+/-10V
10
11
+/-5V
20
12
+/-2.5V
50
13
+/-1V
100
0
+/-0.5V
200
1
+/-0.25V
500
2
+/-0.1V
1000
3
+/-0.05V
2000
4
+/-0.025V
5000
5
+/-0.01V
Thermocouple
WinDaq Acquisition
Thermocouple Setting
Index
Range (°C)
B
0
250 to 1820
E
1
-200 to 1000
J
2
-210 to 1200
K
3
-200 to 1372
N
4
-200 to 1300
R
5
-50 to 1768
S
6
-50 to 1768
T
7
-200 to 400
DI-158U, DI-410, DI-500, DI-510, DI-715B, DI-720, DI-722, DI-725, DI-740, DI-750, DI-760
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-10V
2
1
+/-5V
4
2
+/-2.5V
8
3
+/-1.25V
DI-158UP
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-64V
2
1
+/-32V
4
2
+/-16V
8
3
+/-8V
16
4
+/-4V
32
5
+/-2V
64
6
+/-1V
128
7
+/-0.5V
256
8
+/-0.25V
512
9
+/-0.125V
DI-200, DI-222, DI-700, DI-710
WinDaq Acquisition
Gain Setting
Range
PGL
PGH
Gain Index
PGL
PGH
1
1
0
+/-10V
+/-10V
10
2
1
+/-1V
+/-5V
100
4
2
+/-100mV
+/-2.5V
1000
8
3
+/-10mV
+/-1.25V
DI-201, DI-220
WinDaq Acquisition
Gain Setting
Range
PGL
PGH
Gain Index
PGL
PGH
1
1
0
+/-5V
+/-5V
10
2
1
+/-0.5V
+/-2.5V
100
4
2
+/-0.05V
+/-1.25V
1000
8
3
+/-0.005V
+/-0.625V
DI-400
WinDaq Acquisition
Gain Setting
Range
PGL
PGH
Gain Index
PGL
PGH
1
1
0
+/-10V
+/-10V
10
2
1
+/-1V
+/-5V
100
4
2
+/-100mV
+/-2.5V
N/A
8
3
N/A
+/-1.25V
DI-722 Amplified, DI-725E
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-20V
2
1
+/-10V
4
2
+/-5V
8
3
+/-2.5V
DI-730 and DI-4730
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
4
+/-1000V
10
5
+/-100V
100
0
+/-10V
1000
1
+/-1V
10000
2
+/-100mV
100000
3
+/-10mV
DI-500, DI-510 High Voltage
WinDaq Acquisition
Gain Setting
Gain Index
Range
1
0
+/-1000V
2
1
+/-500V
4
2
+/-250V
8
3
+/-125V
DI-5001 (jumper selectable)
WinDaq Acquisition
Gain Setting
Range
jumper +/-5
jumper +/-10
Gain Index
jumper +/-5
jumper +/-10
1
1
0
+/-5V
+/-10V
2
2
1
+/-2.5V
+/-5V
4
4
2
+/-1.25V
+/-2.5V
8
8
3
+/-0.625V
+/-1.25V
