General Information > Keyboard Operations
Horizontal Navigation | Vertical Navigation | Selecting a Strip
Keyboard Operations
  This section explains the keyboard operations used with the WinDaq Waveform Browser.
Left Arrow scrolls 16 pixels toward beginning of file unless data cursor is on and Scroll Lock is off, in which case the data cursor is moved left 1 pixel.
Right Arrow scrolls 16 pixels toward end of file unless data cursor is on and Scroll Lock is off, in which case the data cursor is moved right 1 pixel.
Ctrl Page Up moves one screen toward beginning of file.
Ctrl Page Down moves one screen toward end of file.
Gray * moves data cursor to center of screen. If Scroll Lock is on, center data points under data cursor.
Home moves data cursor to left end of screen.
End moves data cursor to right end of screen.
Ctrl Home moves beginning of file under data cursor.
Ctrl End moves end of file under data cursor.
Vertical Navigation
Up Arrow expands selected waveform to twice its size.
Down Arrow shrinks selected waveform to half its size, making rest of commands move farther.
Page Up offsets selected waveform up 1 pixel.
Page Down offsets selected waveform down 1 pixel.
- offsets selected waveform up 10 pixels.
+ offsets selected waveform down 10 pixels.
Selecting a Strip (Selecting a Waveform)
Type the strip number (1-9 or A-W), but not higher than the highest strip number visible in the current screen format. Type 0 to deselect.
Assigning a Channel
If a strip is selected (number in reverse video), type "=" and the channel number. If rectangle is still flashing after typing 1 or 2, press a non-numeric key to terminate the entry. Type 0 to remove the waveform displayed in the selected strip.
Exiting
Press ALT, then F, then X, use Right or Left arrow to select appropriate button, and Enter to push it.
