DI-8B42-01 4-20mA Current Loop Transmitter Workaround
View pdf View the pdf
On this Page
Symptoms
Cause
Resolution
   Make sure that your connections are correct
   Place a 0.02µF ceramic disc capacitor between In+ and Ex+
Applies To
Symptoms
Readings in WinDaq appear erratic when attempting to acquire data from a 2-wire transmitter using a DI-8B42-01 module.
Cause
Rarely, the DI-8B42-01 module could go into oscillation with certain transducers.
Resolution
The transmitter should be connected across Ex+ and In+.
If your connections are correct; place a 0.02µF ceramic disc capacitor between In+ and Ex+.
place capacitor as shown
Applies To
DI-718B(x), DI-788 and DI-78B input expanders containing DI-8B42-01 modules.
