This option allows you to enable/disable the display of user channel annotation provided during waveform recording. To enable user annotation (if disabled, or disable it if enabled):
the Options menu click on User Annotation.
Options User Annotation (ALT,
O, U).
When user annotation is enabled a check mark will be displayed on the Options menu immediately preceding the User Annotation command.
Note that the display annotation options can be enabled in virtually any combination to provide the desired result. However, in some instances one annotation option will override another.
See User Annotation for information on how to change the user annotation.
