di_anin is an immediate function that takes one data sample from a single analog input channel. Use di_inlist to stream data from multiple channels.
int di_anin (analog_input); |
struct di_anin_struct{ |
unsigned chan; |
/* input channel. 0 to 255 */ |
unsigned diff; |
/* input configuration (single-ended or diff) */ |
unsigned gain; |
/* gain setting */ |
unsigned unipolar; |
/* unipolar/bipolar; 0=bipolar, 1=unipolar */ |
}*analog_input; |
chan
allows you to specify the input channel you wish to sample. Values for chan
can range from 0 to 255, dependent upon the hardware device.
chan
= channel # - 1 for all devices except the DI-220 series (for which the channels are numbered starting at 1).
chan
= channel # - 1 + 32*(letter - "A" + 1) for devices on 32-channel expanders labeled by letters.
diff
allows you to specify whether the channel specified by chan
is single-ended or differential (0 or 1).
gain
allows you to specify a gain factor (gain index) for the channel specified by chan
. Possible gain settings are device dependent. See Gain Reference for a list of all possible gain factors and ranges.
With the DI-221TC, you can specify a gain factor for linear or non-linear inputs.
With the DI-401 this structure element is reserved for compatibility (gain is fixed at 1).
unipolar allows you to specify whether the channel specified by chan
is a unipolar or bipolar signal. On DI-401 instruments, this structure element is reserved for compatibility. On DI-400, DI-410, DI-500, DI-510, DI-720, DI-730, DI-78x, and DI-5001 instruments, unipolar configuration is not supported (unipolar must be 0).
di_anin
returns channel data in Counts. The data format is resolution/instrument dependent.
12-bit: | DI-220, DI-221, DI-222 |
14-bit: | DI-400, DI-410, DI-500, DI-510, DI-71x, DI-720, DI-730, DI-78x, and DI-5001 |
16-bit: | DI-720, DI-730, DI-78x, and DI-5001 |
See Converting Counts to Volts.
On Ethernet and USB instruments, this function should not be issued while an input, output, or simultaneous input and output scanning operation is in progress. If it is, the scanning operation will halt. On all other instruments, scanning will not halt when this function is issued, but di_anin
will only execute successfully while output scanning (the di_anin
function will be ignored when input scanning or simultaneously input and output scanning).
Note: di_anin
is not supported on the first eight channels (the high voltage channels located on the front of the instrument) of the DI-730.
#include "200sdk.h" |
int errcode; |
struct di_anin_struct anin; |
char errstr[255]; |
main() |
int i; |
if(errcode = di_open()){ |
/* open the device for comm */ |
di_strerr(errcode,errstr); |
printf("%s",errstr); |
else |
printf("Device installed successfully.....\n"); |
anin.chan = 5; |
/* channel 5 */ |
anin.diff = 0; |
/* single ended input channel */ |
anin.gain = 0; |
/* gain of 1 */ |
anin.unipolar = 0; |
/* bipolar */ |
i = di_anin(&anin)) |
/* get analog input */ |
printf("Channel 5 = %d",i); |
di_close (); |
