The di_buffer_size
function returns the size of the input buffer as an unsigned integer.
unsigned di_buffer_size(void);
none
The di_buffer_size
function returns an unsigned integer equal to the size of the input buffer.
none
This function is used to get the size of the input buffer when the buffer is allocated by WinDaq software. The size of the buffer is needed to determine the proper index for use with the di_copy_buffer
function.
buffer_size = di_buffer_size() |
'get size of buffer |
buffer_pointer = di_buffer_status(0) - 100 |
'get the last 100 data points |
If buffer_pointer < 0 Then |
'check for wrap around |
buffer_pointer = buffer_size + buffer_pointer |
'adjust pointer if wrap around |
End If
i% = di_copy_buffer(buffer_pointer, inbuffer(0), 100) |
'copy buffer to user array |
