The di_info
function loads a structure with information about the device.
int di_info(info); |
struct di_info_struct{ |
unsigned port; |
/* device port address */ |
unsigned buf_in_chn; |
/* device input channel */ |
unsigned buf_out_chn; |
/* device output channel (for products that support output) or reserved for compatibility */ |
unsigned sft_lvl; |
/* software interrupt level */ |
unsigned hrd_lvl; |
/* hardware interrupt level */ |
int huge *buf_in_ptr; |
/* input buffer pointer */ |
unsigned buf_in_size; |
/* input buffer size (in words) */ |
int huge *buf_out_ptr; |
/* output buffer pointer (for products that support output) or reserved for compatibility */ |
unsigned buf_out_size; |
/* output buffer size,in words (for products that support output) or reserved for compatibility */ |
char tsr_version[20]; |
/* TSR version */ |
char dsp_version[20]; |
/* DSP program version */ |
char sdk_version[20]; |
/* SDK library version */ |
unsigned long serial_no; |
/* PCB serial no. */ |
unsigned long last_cal; |
/* last calibration time in sec since 1/1/1970 */ |
char board_id[10]; |
/* PCB model name */ |
char pgh_pgl; |
/* type of PGA; 0 = PGH, 1 = PGL or reserved for compatibility */ |
char hrdwr_rev; |
/* ASCII char REV letter */ |
char pal0_rev; |
/* ASCII char REV of PAL0 */ |
char pal1_rev; |
/* ASCII char REV of PAL1 */ |
}*info; |
Elements buf_in_chn
and buf_out_chn
equal the device's hardware DMA channel or software FIFO number, depending on the instrument.
The eighth character of the char dsp_version [20]
string is a 14-bit or 16-bit resolution flag. For instruments capable of recording with either 14 or 16 bits of resolution (i.e., DI-720, DI-730, and DI-5001), the eighth character of this string shows “A” for 14-bit and “B” for 16-bit. For all other instruments (i.e., the other instruments that are not capable of recording with either 14- or 16-bits of measurement resolution), “A” means the instrument is using the non-mux DSP program and “B” means the instrument is using the mux version of the DSP program.
DI_NO_ERR | No error |
DI_OPENED_ERR | Device not opened |
DI_COMM_ERR | Communication error |
DI_INFO_ERR | Information error |
The structures returned by di_copy_header32
and di_info32
have padding to align 32-bit structure members declared in HDRDEF32.H on 32-bit boundaries. They should be used with 32-bit Visual Basic or any 32-bit compiler that does not support the recommended -Zp2 switch on the command line.
For DI-1100, DI-1110, DI-1120, DI-2008, DI-2108, DI-2108P, DI-4108,or DI-4208, DI-4718B, if multiple devices are opened, the device for which di_open returns information may be specified by calling di_set_rel_dev(int relindx), where 0 specifies the device with the lowest serial number or the 0-based position of the device in the list of serial numbers passed to di_open. This index may also be set by calling di_digout with bits 14 and 15 both set to select the device used by di_digin, which should only be called for a device that is not scanning. The di_info_struct members buf_in_size returns a truncated value if the size in samples exceeds 0xFFFF. The correct size can be found by calling di_info_32 and looking at the buf_in_size member of di_info_struct_32.
#include "200sdk.h" |
int errcode; |
struct di_info_struct info; |
char errstr[255]; |
main() |
if(errcode = di_open()){ |
/* open the device for comm */ |
di_strerr(errcode,errstr); |
printf("%s",errstr); |
else{ |
printf("Device installed successfully.....\n"); |
if(errcode = di_info(&info)){ |
/* Get info about the device*/ |
else{ |
printf("\nPort: %04X\n",info.port); |
printf("Input chn: %04X\n",info.buf_in_chn); |
printf("Output chn: %04X\n",info.buf_out_chn); |
printf("Sft lvl: %04X\n",info.sft_lvl); |
printf("Hrd lvl: %04X\n",info.hrd_lvl); |
printf("Input ptr: %08lX\n",info.buf_in_ptr); |
printf("Output ptr: %08lX\n",info.buf_out_ptr); |
printf("Input size: %04X\n",info.buf_in_size); |
printf("Output size: %04X\n",info.buf_out_size); |
printf("TSR Ver: %s\n",info.tsr_version); |
printf("DSP Ver: %s\n",info.dsp_version); |
printf("SDK Ver: %s\n",info.sdk_version); |
printf("Serial #: %08lX\n",info.serial_no); |
printf("Last cal: %s",ctime(&info.last_cal)); |
printf('Board ID: %s\n",info.board_id); |
printf("PGH/PGL(1/0): %0x1\n",info.pgh_pgl); |
printf("Hard Rev: %c\n",info.hrdwr_rev); |
printf("PAL0 Rev: %c\n",info.pal0_rev); |
printf("PAL1 Rev: %c\n",info.pal1_rev); |
di_close(); |
