Functions > di_outlist
Syntax
The di_outlist function initializes the output list (output functions are not available on all instruments).
Note: This function has to be called after di_list_length and before di_start_scan. Note that the two LSB's of data in each location of the output buffer must be zero.
Syntax
int di_outlist(output_list);
struct di_outlist_struct{
unsigned unipolar;
/* specifies unipolar/bipolar or DAC0/DAC1 */
unsigned digital;
/* specifies digital or analog data */
unsigned dig_out_enable;
/* enables digital output */
unsigned dig_data;
/* digital data is D0 through D7 */
unsigned counter;
/* scan position counter */
}*output_list;
Parameters
unipolar
unipolar specifies a unipolar/bipolar signal for DI-2xx instruments or specifies DAC1/DAC2 for DI-400, DI-410, DI-500, DI-510 and Printer Port versions of the DI-720, DI-730, DI-740, and DI-5001.
DI-400, DI-410, DI-500, DI-510, DI-720/730/740/5001 Printer Port devices
DI-220, DI-221TC, DI-222
digital
digital = 1 sets the buffer data to digital data
digital = 0 sets the buffer data to analog data
dig_out_enable
dig_out_enable = 1 enabled the digital output
dig_out_enable = 0 disables the digital output
dig_data
The digital data is D0 through D7.
counter
Use counter to specify an output rate.
Where:
O = desired output rate of the output list entry
B = burst rate of the instrument
L = length of the input or output list (whichever is greater)
C = counter
Return Value
DI_NO_ERR No error
DI_OPENED_ERR Device not opened
DI_COMM_ERR Communication error
DI_OUTLIST_ERR Value is outlist structure out of range
Dependencies
di_open
di_list_length
Remarks
Since simultaneous input and output operations are possible, some consideration must be given to input and output synchronization. The following table illustrates the order of each input/output operation, with respect to the other operations. In this example, there are 10 elements each in the input and output scan lists. Each input or output is referenced to its position in the input or output scan list.
Sample Number Analog
Input
Analog
Output
Digital In
Buffer
Digital Out
Buffer
Digital Out
Inlist
Digital Out
Outlist
1 - - - - 0 -
2 - - - 0 1 0
3 0 - 0 1 2 1
4 1 0 1 2 3 2
5 2 1 2 3 4 3
6 3 2 3 4 5 4
7 4 3 4 5 6 5
8 5 4 5 6 7 6
9 6 5 6 7 8 7
10 7 6 7 8 9 8
11 8 7 8 9 0 9
12 9 8 9 0 1 0
13 0 9 0 1 2 1
14 1 0 1 2 3 2
15 2 1 2 3 4 3
16 3 2 3 4 5 4
17 4 3 4 5 6 5
18 5 4 5 6 7 6
19 6 5 6 7 8 7
20 7 6 7 8 9 8
Sample Code
#include "200sdk.h"
int errcode;
#define ODIM 16;
/* largest value allowed */
struct di_outlist_struct outlist[ODIM] = {0};
/* input list cleared */
char errstr[255];
main()
int i;
if(errcode = di_open()){
/* open the device for comm */
di_strerr(errcode,errstr);
printf("%s",errstr);
else
printf("Device installed successfully.....\n");
/* The following initializes scan list position 0 and must be repeated for all positions intended to be scanned */
outlist[0].unipolar = 0;
/* bipolar */
outlist[0].digital = 1;
/* buffer data is digital */
outlist[0] dig_out_enable = 0;
/* disable digital output */
outlist[0].dig_data = 0x20;
/* digital data to be output */
outlist[0].counter = 10;
/* init counter */
di_list_length (ODIM, 0);
if(errcode = di_outlist(outlist)){
/* initialize output list */
else
printf("Output list initialized.....\n");
di_close();
