The di_set_port_mode
function sets the printer port mode.
Note: Since calling di_open
configures the parallel port in the fastest mode for which the device returns a signature, only use di_set_port_mode
when you want to set the port to a slower mode.
int di_set_port_mode(mode); |
unsigned mode; |
/* sets the printer port mode */ |
mode
= 0 returns the current mode
mode
= 1 sets the printer port to EPP
mode
= 2 sets the printer port to Bi-directional
mode
= 3 sets the printer port to Standard
The return value is the current mode (1, 2, or 3) or:
0 = EPP mode invalid for port with less than five contiguous I/O addresses
4 = Attempt to set EPP mode for a DI-220 series device.
Windows XP accesses parallel ports every five seconds to determine if a device is attached using commands that disable DI-220 Series devices. Programs using the SDK for DI-220 series devices should be run from a batch file that runs 220LDRNT loader first or execute the 220LDRNT loader with appropriate command line arguments before calling di_open
and retry if di_open
fails.
di_open(1); |
/* for a device on port LPT1 */ |
di_set_port(2); |
/* use an EPP port like a port in bidirectional mode */ |
