Reference Materials > Device Drivers and Device IDs
  Windows Version
Hardware 95 98 NT ME 2000 XP Vista, 7, 8
All Serial Devices1
N/A Same as XP N/A
It is not necessary to specify DeviceDriver for products using a physical COM port
DeviceID = "COMnn DeviceName BaudRate"2
nn=COM port number3
(see footnotes below for an example)
DI-145, DI-148, DI-149, DI-155, DI-158, DI-245, DI-710, DI-715B, and DI-718B USB versions1
Only necessary with multiple devices
nn=COM port number3
DI-220, DI-221, and DI-222
DeviceDriver = DI22nNT.DLL
DeviceID = n
n = LPT#
DI-400, DI-401, and DI-410
Device Driver = DI40nNT.DLL
DeviceID = n
n=WinRT virtual device # 4
DI-710, DI-715B, and DI-718B, and DI-718Bx Ethernet versions
DeviceDriver = DI6nnNT.DLL
nn =0 to 39 are reserved
40 to 69 for DI-710-E, DI-715B-E instruments
70-99 for DI-718B-E and DI-718Bx instruments5
DeviceID = IP address (example "192.168.1.0")
or
DeviceID = IP address:Port (for Remote Devices - example "192.168.1.0:10001")
DI-720/730/740/760-EN
DeviceDriver = DI8nnNT.DLL
nn = the order of WinDaq/IP installation - look in c:\windows\tpdataq.ini
DI-500/510/720/730/740/750/760-P
DeviceDriver = DI50nNT.DLL
DeviceID = n
n = LPT#
N/A
DI-720/730/740/760-USB
N/A
Same as XP
N/A
DeviceDriver = DI72nNT.DLL
n =DeviceID = USB ID of the device
DI-700
N/A
Same as XP
N/A
DeviceDriver = DI70nNT.DLL
n = DeviceID = USB ID of the device
 1The DI-145, DI-148U, DI-149, DI-155, DI-158U/UP, DI-245, and DI-71x USB versions all use a virtual COM port. Some products use a virtual COM port even though they may have an alternate interface connection (like USB). Such products use the serial port device driver and ID. For a list of devices using a Virtual COM Port see Virtual COM Ports.
2DeviceName = Model number of the device. BaudRate = the baud rate. For a listing of baud rates see Baud Rate. For Example: For a DI-158U installed at COM 2 with 38400 Baud the DeviceID = "COM2 158 38400"; a DI-145 installed at COM 8 would be: "COM8 145 4800".
3As specified during installation of the device. COM port numbers of 01 to 99 are supported. Example: For a Serial device installed to COM 1 the DeviceDriver=DI101NT.DLL. Go to Virtual COM Ports for instructions on finding the correct COM port.
4Virtual Device # can be found in c:\Windows\tpdataq.ini, or at the end of the WinDaq installation.
5The order of WinDaq/IP installation - look in title bar of WinDaq Acquisition when running device or check your installation directory for file(s) named WDQDK6nn.EXE.
