Change Ethernet Adapter
Each installed device may be connected through a different Ethernet Adapter on your PC. Designate which device is connected to which adapter using the Change Ethernet Adapter command.
  1. Select the desired device.
  2. Click on the drop down commands and select Change Ethernet Adapter.
  1. Select the Adapter from the list provided and click OK.
