Configure Auto Record
The Configure Auto-record command allows you to create recording settings for a single device that will automatically be called and run when the Start WinDaq button is clicked.
  1. Select the desired device
  2. Click on the drop down commands and select Configure Auto-record.
  1. Use the Browse button to the right of the File Name text box to designate a file name and location for your recorded data.
  2. Enter the amount of time to record in days, hours, minutes, and seconds in DD(days):HH(hours):MM(minutes):SS(seconds) format in the Time to Record text box. 1:00 designates one minute, zero seconds.
  3. If you would like to use a Setup File (a previously recorded file) click the Browse button to the right of the Setup File Name text box and select the desired setup file. Check the Use Setup File checkbox. All data acquisition parameters from the selected setup file (e.g., number of channels, channel type, scaling constants, engineering units, display format, compression, display mode, gain, etc.) are ported from the previously recorded file and used to record the new data file.
  4. Check the Auto Record checkbox to enable the settings.
  5. Click the OK button. These settings are now saved for that device.
  6. Select the device then click the Start WinDaq button to record data based on the settings saved in the Configure Auto-record dialog.
To turn off auto-record, access the Configure Auto-record dialog and un-check the Auto Record checkbox. Configure Auto Record is device dependant (i.e., you may save different settings for each device).
