The di_buffer_alloc
function allocates a memory block to temporarily store channel data.
int _huge *di_buffer_alloc(chn,size); |
unsigned chn; |
/* specifies whether buffer is for input (0) or output (1) data */ |
unsigned size; |
/* words to allocate for buffer */ |
For DI-1100, DI-1110, DI-1120, DI-2008, DI-2108, DI-2108P, DI-4108, DI-4208, or DI-4718B to allow high-speed operation of devices that support synchronized scanning, you can specify an input buffer size of 0 to allocate 0x10000L samples times the number of devices of the same model or compatible models supported by the DLL opened by di_open. None of these devices support an output buffer.
0 = input
1 = output
Note: Output functions are not available on all instruments. Check your hardware manual for output specifications.
The least significant bit of chn
is the only bit checked to determine input or output.
The di_buffer_alloc
function allocates a memory block of at least size
words (1 word = 1 sample).
The di_buffer_alloc
function returns a huge integer pointer if it can allocate memory of size
and if a buffer has not been previously allocated for chn
. NULL is returned if allocation fails.
It is a good idea to allocate a size
divisible by the total number of channels. Larger buffer sizes minimize the probability of an overrun at high sample rates. Maximum buffer size is always 65535 16-bit words. Use the following table to determine minimum buffer size.
Instrument | If allocating only one buffer | If allocating an Input and Output buffer | ||
Input Buffer | Output Buffer | |||
DI-194, DI-145, DI-148, DI-149, DI-158, DI-71x* | 4096 | N/A | N/A | |
DI-220 Series | 8182 | 4091 | 4091 | |
DI-400 Series | 15000 | 8192 | 6144 | |
DI-700* | 64 | N/A | N/A | |
DI-500, DI-720, DI-730, DI-5001 Printer Port Devices | 7500 | 4096 | 4096 | |
DI-500, DI-720, DI-730, DI-78x, DI-5001 Ethernet Devices | 7500 | N/A | N/A | |
DI-500, DI-720, DI-730, DI-78x, DI-5001 USB Devices | 15000 | N/A | N/A | |
* Input buffer only supported |
De-allocate the memory block with di_buffer_free.
For DI-1100, DI-1110, DI-1120, DI-2008,DI-2108, DI-2108P, DI-4108, or DI-4208 to allow high-speed operation of devices that support synchronized scanning, you can specify an input buffer size of 0 to allocate 0x10000L samples times the number of devices of the same model or compatible models supported by the DLL opened by di_open. None of these devices support an output buffer.
#include "200sdk.h" |
int *input_buffer; |
int *output_buffer; |
main() |
di_open (); |
if((input_buffer = di_buffer_alloc(0,4096)) == NULL) |
/* allocate input buffer */ |
printf("Insufficient memory or input buffer already allocated...\n"); |
if((output_buffer = di_buffer_alloc(1,4096)) == NULL) |
/* allocate output buffer */ |
printf("Insufficient memory or output buffer already allocated...\n"); |
di_close (); |
