Functions > di_copy_array
Syntax
The di_copy_array function copies the contents of a user specified array into the output buffer. The size of the buffer is set by di_buffer_alloc.
Syntax
int di_copy_array (buf_index, source, number);
unsigned buf_index;
/* specifies the offset from the first element in the buffer */
int _huge *source;
/* specifies source array name */
unsigned number;
/* specifies how many array elements to copy to the output buffer */
Parameters
buf_index
buf_index specifies the offset from the first element in the buffer. If an offset of zero is specified data is copied to the output buffer starting with the very first element in the array. Specifying an offset of 10 will start the copy process with the tenth value of the output buffer (etc.).
_huge *source
Specifies the source array name. The _huge pointer allows C programmers to specify a source array larger than 64k bytes.
number
Specifies how many array elements to copy to the output buffer.
Return Value
DI_NO_ERR No error
Dependencies
di_buffer_alloc
Remarks
This function also supports buffer wrapping (i.e., if buf_index and number exceed the buffer size in words, the copy process continues to the start of the buffer). Thedi_buffer_status function can be used to compute buf_index, which must be between 0 and (buffer size - 1). Although number may be as large as the buffer size, active scanning may concurrently output values starting at the index returned by di_buffer_status.
Sample Code
Declare Sub di_copy_array Lib "200SDK.DLL" (ByVal buf_index%, source%(), ByVal number%)
Dim out_buff%
'offset in the output buffer
Dim analog_out%(1000)
'array used to store analog out
Dim number%
'number of samples to copy
Sub Form_Load ()
' This copies the first 500 elements of analog_out to the output buffer at offset 0
buf_index = 0
number = 500
di_copy_array buf_index,analog_out(0),number
End Sub
