Functions > di_status_read
Syntax
The di_status_read function reads the status of the input buffer (opened by di_buffer_alloc) and copies the newest data points collected in the buffer from the previous call of this function to your specified destination.
Syntax
unsigned di_status_read(dest,num_scans);
int far * dest;
/* destination for input data buffer */
unsigned num_scans;
/* number of data points to be copied */
Parameters
dest
User-specified destination for the input data collected.
num_scans
The number of data points to be copied. If there are not enough data points available in the input buffer, di_status_read will wait until there are enough available. If num_scans is set to 0, di_status_read will return the number of data points available without waiting.
Return Value
The di_status_read function returns the number of data points in the buffer which still have not been copied.
Dependencies
di_open
di_inlist
di_buffer_alloc
di_start_scan
Remarks
none
Sample Code
#include "200sdk.h"
struct di_mode_struct mode = {0};
struct di_inlist_struct inlist[256] = {0};
char errstr[255];
int analog_in[1024];
main()
list_length = 5;
if(errcode = di_open()){
/* open the device for comm */
di_strerr(errcode,errstr);
printf("%s",errstr);
if((input_buffer = di_buffer_alloc(0,4096) == NULL)
/* allocate 4096 words for input */
printf("Insufficient memory or input buffer already allocated...\n");
if(errcode = di_inlist(inlist))
/* Set up the input list */
printf("Input list error...\n");
if(errcode = di_mode(mode))
/* Set mode */
printf("Mode error...\n");
if(errcode = di_start_scan())
/* Start scanning */
printf("Start scan error...\n");
while(di_status_read (analog_in, 0) < 100);
/* Main loop executes until 100 data points are accumulated. */
di_status_read (analog_in, 100);
/* Copy 100 data points to the analog_in buffer. */
if(errcode = di_close()){
/* close the device */
