You must use the Start Recording
button to record data with multiple Synced devices. Use the Change Session Settings drop down
command to change the recording session settings. Use the WinDaq
Acquisition File > Record
(or press F4) command to record data with a single unit.
Select the synced devices (must
be in the same group) you would like to record data from. Any number of
units can be used in the group. Use Control
+ Left-click or Shift + Left-click
to select multiple devices.
Click the Start
WinDaq button. A WinDaq Acquisition software window will open for
each device selected.
Change channel settings, calibration,
and display options independently for each device using each instance
of WinDaq. Most WinDaq
menu items are available when recording synced devices with the following
exceptions: The Open and Record menu items in the File Menu are not available;
The Triggered Mode, Triggered Storage, and Remote Storage menu items in
the Options Menu are not available.
Click the Start
Recording button to record data to disk. You may Start and Stop
recording as many times as you like until the time specified in the Change
Session Settings dialog box has filled. Once the file is full, you must
close each instance of WinDaq Acquisition and open a new session.
