Note: This feature is for DI-149, DI-155, and DI-2108 Counter channels only.
The Reset Count on New File Record preference allows you to reset the counts in Channel 11 of DI-149, DI-155, and DI-2108 instruments back to zero every time you record to a new file with the Edit > Preferences > Record Next File on Full feature enabled.
Use the Edit > Preferences > Reset Count on Manual Record in WINDAQ Acquisition software to reset counts to zero every time you begin recording a data file using the File > Record command (F4).
on Reset Count on New File Record.
Edit Preferences Reset Count on New File Record (ALT, E, P, N).
When Reset Count on New File Record is enabled, a check mark is displayed on the Edit Preferences submenu immediately preceding the Reset Count on New File Record command.
