Convert GBD Files to WDH Format
Our new GBD to WDH converter gives you the ability to convert GBD files, created using GL220, or  GL820 series instruments, to WDH format. Resulting WDH files can be opened in the WinDaq Waveform Browser for observation and analysis. For convenience, and to maintain 16-bit resolution, a high-res version of the WinDaq Waveform Browser is installed along with the converter.
Convert01
The straight-forward user interface allows you to select a single GBD file, or multiple files using ‘Batch mode’. As the name implies, batch mode allows you to convert a large number of files, with a single click.
Along with the data, scaling values, user annotation and event marks are transferred to the resulting WDH file.
Graph01
Source GBD file
Windaq01
Resulting WDH file
You can download the WinDaq Converter beta here.
Comments and suggestions are welcome!
 Categories: Data Logger, WinDaq Data Acquisition Software
 Tags: ,
5 Comments
  1. Lynn Fuller
    Posted September 24, 2013 at 1:04 pm Permalink
    I attempted to convert a 3 channel file recorded at 1 mS resolution resulting in a file size of approx. 0.8 GB. I got the following error message:
    Processing:
    Source: E:\13-09-23\10_31_42\130923-103142_UG_rep001.GBD
    Destination: C:\Users\Lynn\Documents\WINDAQ\130923-103142_UG_rep001.wdh
    Conversion started…
    MSG: Index was outside the bounds of the array.
    Conversion did not complete successfully.
    Any suggestions?
    • Posted September 25, 2013 at 10:55 am Permalink
      Note that the conversion utility will not work for the GL900 or GL7000 Graphtec systems. Since 1 mS sampling intervals are far smaller than the supported GL220 and GL820 loggers allow, I suspect that your instrument is not supported.
  2. Henry Sick
    Posted June 9, 2014 at 10:16 pm Permalink
    The software throws and error regarding expected software versions. Please see attached and update accordingly.
    • Henry Sick
      Conversion started…
      MSG: Exception of type ‘Dataq.VersionException’ was thrown.
      libdifile
      Expected: 1.0.0.41
      Found: 1.0.0.46
      • Posted June 16, 2014 at 4:22 pm Permalink
        What instrument created the GBD file? Note that this software supports only the GL820 and the GL220.
