Command Hierarchy
To help you find the information you want,
a menu hierarchy of commands utilized with the WinDaq Waveform Browser
is included here. Each command is listed according to the Menu it appears
in. The command is followed by its activating accelerator key(s), and
the commands are linked to references within the help file when applicable.
The Menus available for WinDaq Waveform Browser are File,
Edit, View, Search,
Scaling, Transform, X-Y, Options, and Help.
File
Open…, CTRL+O
Save All, Open Next,
ALT+F12
Save Cal,
Open Next, CTRL+F11
No Save, Open
Next, CTRL+F12
Save,
CTRL+S
Save As…,
CTRL+V
Export to Excel, CTRL + Shift + X
Calculate…,
ALT+M
Note,
CTRL+N
Commented
Note…, ALT+N
Print…,
CTRL+P
Print
Setup...
Exit…
Edit
Undo,
CTRL+Z
Copy,
CTRL+C
Engineering Unit Settings..., CTRL+F8
Reset EU..., CTRL+F12
Transfer Calibration..., CTRL+F9
Restore all EU..., CTRL+F10
Delete
Mark, Delete
Insert
Mark, Insert
Clear Marks
to TM, CTRL+SHIFT+E
Channel Annotations…,
ALT+F11
Transfer Channel Annotation…,
ALT+Shift+F11
Compression…,
F7
View
Assign
Channel…, =
Assign Range…,
Forward
Range, CTRL+↓
Backward
Range, CTRL+↑
Format ScreenCommand
Options (1 Waveform (SHIFT+1); 2 Waveforms, overlapped (SHIFT+2);
2 Waveforms (SHIFT+3); 4 Waveforms, overlapped (SHIFT+4); 4 Waveforms
(SHIFT+5); 8 Waveforms, overlapped (SHIFT+6); 8 Waveforms (SHIFT+7); 16
Waveforms, overlapped (SHIFT+8); 16 Waveforms (SHIFT+9); 32 Waveforms,
overlapped (SHIFT+0); User-specified format... (SHIFT+-))
Statistics…,
CTRL+T
DAC Playback…,
CTRL+SHIFT+D
Channel
Settings…, F10
Event
Markers…, F8
Next
Palette, ALT+P
Previous
Palette, ALT+SHIFT+P
User
Palette…, CTRL+U
Split
Exit/Enter
Split, CTRL+Y
More Bottom Y,
Y
Less Bottom
Y, ALT+Y
Left
Limit, ALT+F1
Right
Limit, CTRL+F1
Toggle
Pane, F6
Refresh,
SHIFT+F5
Search
Next
Mark, CTRL+→
Previous
Mark, CTRL+←
Peak on
Screen, CTRL+K
Valley on Screen,
ALT+K
Go to
TM Position, Gray /
Center
Cursor, Gray *
Go to Range…,
CTRL+R
Go to Time…,
CTRL+SHIFT+T
Auto-Scroll
Right,
ALT+→
Auto-ScrollLeft,
ALT+←
Scaling
Limits…,
ALT+F9
Division...,
CTRL+SHIFT+V
Autoscale,
ALT+A
Show Dynamic Range,
ALT+R
Grow,
Up
Shrink,
Down
Invert,
CTRL+I
Waveform Down 1
Pixel, Gray -
Waveform Down
10 Pixels, CTRL+Gray -
Waveform Up 1 Pixel,
Gray +
Waveform Up 10
Pixels, CTRL+Gray +
Analog
Plot, ALT+SHIFT+N
Digital Plot…,
ALT+SHIFT+T
Transform
DFT,
CTRL+F
Windowed
FFT…, CTRL+W
Mag Engr
Units, CTRL+M
Scale
DB, SHIFT+F4
Compress
FRQ…, CTRL+F3
Erase
Frequency, CTRL+E
High-pass
Filter, CTRL+H
Low-pass
Filter, CTRL+L
Inverse
Transform, ALT+I
Average
Power…, CTRL+A
Output
FRQ Data…, ALT+D
X-Y
Exit/Enter X-Y,
CTRL+X
Deltas,
ALT+SHIFT+D
Slopes,
CTRL+SHIFT+S
Area,
ALT+F3
Adjust
Area, SHIFT+F3
Clear
Areas, CTRL+SHIFT+C
Options
Data Cursor,
ALT+F2
Data
Display, F2
Limit
& Frequency Display, ALT+L
Units/Division,
CTRL+SHIFT+U
Acquisition
Assignments, CTRL+SHIFT+A
Enable
Live Display, F3
Select
Live DisplayCommand Options (Time from Beginning
of File, Difference
from TM pt, %
Change from TM pt, Slope
of line to TM pt)
Enable Time Marker,
F4
Select
Marker DisplayCommand Options (Time
from Marker, Samples
from Marker, Hz
for Cycle to Marker, Cycles/min
for Cycle to Marker)
%EOF,
F5
Cursor
Time, CTRL+SHIFT+R
Start
Time, CTRL+B
End Time,
CTRL+SHIFT+B
Time/Division,
CTRL+D
Event
Marks, ALT+F8
Grids,
ALT+G
Grid Spacing...,
CTRL+G
User
Annotation, ALT+U
Help
Contents
Keyboard
Mouse
Search
for Help On…
How
to Use Help
About
WinDaq…
